Spotted a Silver 34 and a blue SII on the F3 this arvo whilst coming back from a Hunter Valley Crooz organized by the 300ZX peeps
i was in the blue GTST on the F3. Saw you coming up in the rear view mirror. Im stopping and thinking "Hey.... Is he going to slow or what?" And then you ducked into the left lane.
spotted this in the carpark.
R32 GTST with the rear impuls you see on alot of cars on all four corners...
How the hell did they fit?
This guy has also done that too: Here...
spotted r34gtr on federal highway on the way to canberra on satuday morning approx 10am, i think plates were GTR-001. highway patrol sped past me and pulled over the gtr, further down the road there was a defect station happening, a few more skylines in there.
lucky i did not get pulled. i guess a lot of people were on their way to summernats. (i wasnt)
on the way back yesterday in canberra i got pulled over by some cops they said i might get a fine for not having the right rego sticker on, they would not dare defect my car because it was FILTHY and even i wouldnt touch the outside at that stage lol!
how did you get your front bar that bad?
just from going to canberra?
im always up and down fro there and its never been that bad
Spotted a silver R32 GTR at the airport this morning (around 6.30am), in the carpark for the International terminal. I parked almost directly across from it in my Stagea. I didn't have time to catch the plates though.
I'm guessing he/she wouldn't have been able to put three large suitcases and some onboard carry-on luggage in the boot of the GTR - as much as I would have loved an R32 GTR (or GTSt, for that matter), I'm loving the versatility of the Stagea more every time I use it...
nah it wasnt just from going to canberra, i did over 1000kms over the weekend and most of it was through the snowy mountains, which is where all the bugs came from..
i also hit a bird, i have pictures but i wont post them because i feel bad about that whole situation. the bird died, and in the process dented my bonnet, cracked the paint on it, and dented fins on the air con radiator
i cleaned the bugs and bird guts off today i normally have a strong stomach but i really felt like throwing up it smelt and looked so bad and with all the flies eating the dead bugs and bird :blink::)
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
