mel 93H ?
ive seen that a few times round pennant hills area.
i lined up against it couple years ago in my old LS1 - middle aged lady driving with her son in front seat...she didnt run :O
D I F - didnt see me then today did you?
maybe.. what do you drive?
i see alot of cars.. :dry:
spotted abo bob and msp-25t at the runs tonight at WSID... was about to come up and say hey when i found myself doing a commando roll under my gf's umbrella coz the rain started...
cars where looking good guys...
Dont forget me matey...
Gun metal R33 with no rear wing...
yay!!! haha.. was funning watching everyone run for their cars when it started pouring!!!
oh! and adam! so don't believe you made those pants :dry:
and also spotted james in his sexy ceffie at ec :O
AQT- something
White 33gtst on gold rims..
Castle hill area around 4ish pm, waved, no wave back :)
crap, sorry xinhua, i always wave. i musnt have been looking.. yesterday around 4ish i woulda been droping gf off at work at the towers.
spoted 2 so far today, blue 34 gtr :O near flower power around 3:30pm or so.. cant remember if i waved or not :) . but the number plate started with L and was a word, lol.. cant remember too well, was busy checking out the car
also a white r33 gtst s2 with some sort of gtr rear wing.. only wider. saw that going past red field collage this arvo around 5:30pm . i waved but it was like a last min wave
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
