Can't agree more, gotta say loveed the twin exhaust setup on the white GTR , very curious on what make it was...as the sound that come out was sex to the ears...
The exhaust on the white 34 GTR are brand Kakimoto exhaust but why they are so loud is because each turbo has its own seperate complete exhaust compared to normal GTR exhaust as after the dump pipes they join up and make 1 exhaust
Twins shouldn't make things louder just because they're twins. It's exactly the same as any other exhaust- it's up to the muffling capability of the mufflers/resonators. If you have twins but each pipe goes through a really quiet muffler they'll be quiet too.
Get this, driving down Forest rd Hurstville near KFC on Sunday night in my babe black 32 gtst after returning the video and the next I know this yellow flash flew past me which rocked my car like mini "Larry". When I got back on 2 wheels it was yellow R34 gtr (AUG-88*) with large wing I'm note sure what spec this car is. However, I got him at the lights Forest rd and King Georges pulled up next him to compliment his beast but dude turned his head away and pretended I don't exist what a Gerk :D , he does not deserve that car. I have seen the car parked around Hurstville area. That 34 is epitome of a sport car tough.
Actually, it didn't sound that loud from our car when it passed us. Only when it was gunned in the underpass, to which I thought it sounded bloody fantastic. A deep bellow turning it a high pitched scream, just like how a super car should sound, and IMO sounds better then the holden and ford V8's.
Also from what I understand a twin system should be quiter under cruising conditions, as it reduces the resonance compared to a big cannon system.
Edited by godspd
Spotted gunmetal grey Cefiro AWx.xxx somthing like that.
was behind me all the way from Ashfield Bunnings till we got on to Gladesville bridge.
Had IS MOTORSPORT sticker on the front window.. and looked to have flared guards.. ???
Once on the bridge, I got up to about 75-80km's as fast as I could only to hear a distinct rb26 howl as a grey blur went past me..
:huh:
angry, angry car..
Spotted the "Mines" copycat Autostyle 34 yesterday at Wakefield. The car sounded fantastic on the straight but was slow through the infield. the guy kept on grabbing second. Enough Said.
That was me in the 32 at St Leonards, you could see me wave through the tint!
oops
I totally didnt register that was you :P
i was staring at the car like.. I know that from somewhere.. forgot you had that one aswell haha
oops
I gave you a wave, which you obviously didnt see behind the tint :O
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
