Adam, that guy has had them for like 2 years.. I remember the first time I saw them :
spotted a gunmetal r32 gts that used to have a gtr badge on the back but was ripped off still had the glue and shit, TNT 555 I tnink, was sitting behind him for a few minutes
Just saw DHC giving me the hurry up just after rosville bridge on warringah road. Very nice 34 mate!!!! I wanted to play but i have a track day coming up in a few weeks so i dont want to get done before that!!! Besides saw heaps of cops round tonight!!!!
Spotted a non-turbo R33 GTS25 4-door this afternoon in my street - seen it a few times before too - and noticed that the driver was an older (mid-late 40's or above) Indian-looking woman, hahaha...
The wheels looked kinda like the factory mesh-pattern mags on my Stagea, strangely enough.
Spotted a whole heap of SAU buddies down at Northern Beaches Performance last night.... just want to say a big thank you to everyone who showed up, hope the BBQ didn't kill anyone overnight!
Cheers
Stan & the NBP Team
haha sorry dude...hope I wasnt being rude !!
I was lost and frustrated and late to stans bbq opening thingy......I live out near blacktown so im a fish out of water when it comes to chatswood/northen beaches area !!!!!
But yeah yours was the white 32 gtst yeah ?? I think your inner rear lights didnt light up ?
anyways just before I passed you I got stopped by Tolga (I think his nick is GTST on sau ?) just outside the Great Northen(he was giving me directions !) and a white 32 gtr with plates OSAKA went passed and gave it a bit of a rev....
you on here ??? car sounds HOT.
Oh yeah Tolga thanks for the directions once again !!!! It was a breeze to find after you gave me them directions !!!
Edited by shonen
spotted by a silver r33 ..
beeping and waving at me.. umm. sun was in my eyes so I couldnt see the person or plates .. but hi :D
ahaha
also spotted a white r32 chick driver boost past me the other way on old northern.. lots of concentration on her face haha
spotted grenn r33 DR4GON number plates, hey and...
wait for it...
SPINNER HUBCABS!!!
on cumberland highway over M4 wednseday night
yessss i saw him the other day on victoria rd turning off towards five dock.. i had a bit of a giggle
ahaha
Yeah spotted SLIM driving along blindly on castle hill rd!! lol :P
Yeah that was me in the white 32. Your car looks NIIIICCCCEEEEE. Something about a clean black car at night just looks evil specially if its a skyline!!!!!! Not being rude i wanted to have fun but i was reall sketchy comig home from work that night cause the cops were hiding near one of the ramps near my work and flicked on the lights right when i went past them, Turns out they were booking a 300zx that was right near me!!!!!
Hey i live on the beaches but ive never seen that workshop where is it??????
SANGER: We are down in Manly Vale - last night was our opening BBQ, I posted a semi-private invite on the whore thread...
PM me for more details! Feel free to come down anytime, we're there most of the time :D
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
