you missed out on a cutie!!! :D
Pics?
oh and spotted steve.....rather he spotted me on vic rd today around 12ish just down the road from Powerplay.
Yeah, and not even with my GTR ;)
thats strange I saw ando's purple ceffie at Grey Imports on Friday!
I also saw that "car" :)
I've been either seeing (from a distance) or hearing this car just about every weekday now for about 3 weeks, usually around 5.45pm. Still wondering who it is, because by the time I get out the door to see it, it's gone...
OK, I've FINALLY spotted the number plates - it's GTR-10S. Once again, right around 5.45pm.
spotted 2 R32s in the servo across from Livo KK, with a Silvia which had leaked all the engine oil
from the oil fillter i think one of them said,
one of the R32s had a nice purple/pinkyish paint jop and caramel/creamy leather interior very nice..
about 11 last night,
Spotted a black 33 on anzac pde cross of high street, it was involved in an accident, side/head on with another car. :)
Plates were standard ones starting with A. If you're on here hows the car?
RAIN + WET = DRIVE THE F SLOWLY! DONT TAKE CHANCES!
forgot to post this earlier!! pretty sure i saw jerry (wrxhoon) the other night parked on that road that runs parallel to pennant hills road!! it was a white 34 gtr.. and the quick glance i got at the driver, looked like jerry! :)
That road wouldn't be Oaks road mona? Near the M2 tunnel? It was dark and i didn't see you, what kind of car was you driving?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
