First person to spot Liz's car with the new owner was....me!!!
20 mins after liz sold it he turned up at my place to pick up an airbox. I said hold on......This is Liz's car!...and ummmm, your not Liz?? What have you done with Liz? It was some dude nameed Nathan. Hope he takes care of that car liz.
I got new plates for two weeks now and nobody sports my car?? WAAAH
**runs into room and cries with a packets of tim tams and a DVD copy of Beaches**
Spotted a few 32s and 33s running at WSID tonight but one that stood out to me was a black 32 GTST with the plate RBGUN what an absolute machine does anyone know if hes on here? I wanna know if hes still running an RB20 or not and what turbo he has.
Spotted Marsssss driving past my work just then!
:huh: damn.... where do ya work man???
Was coming back from doing a Nasho run where i spotted a burgundy 33... parked at Stamwell then a gunmetal 32 on the way back... they've fixed the road between the 35km/h and the 25km/hr turns.... smooooooov!
should be good for those who turn up this friday
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
