IM OVER SEEING THE AMOUNT OF SKYLINES AROUND... HENCE WHY IM SELLING MINE.... JUST GONNA SELL IT HELL CHEAP IM OVER IT AND JUST WANT TO GET MY 180
SAU IS THE ONLY FORUM IM NOT SPOTTED ON.. I DONT DRIVE MY CAR ANYMORE i HAVE LENT IT TO MY MATE CAUSE i DONT WANT TO DRIVE IT ANYMORE
Um, ok
You're selling it cause other people have Skylines?
Sorry to say (and im not being a smart ass, im just pointing something out) but other people have 180's and 200's etc, there will always be others with the same car as you. In fact i see more CA and SR powered Nissans than RB powered ones day to day
:ninja:
Hi All,
On my way back from getting my car back from North Shore Prestige with the new body kit on it I spotted the following:
2x Black R32's heading towards lindfield on the road that links epping road to pacific hwy past the cementary and m2 exit.... sorry no idea what the name of the road is.
1x Maroon R33 heading down epping rd towards epping
1x Silver R33 turning out of epping onto epping rd heading towards macquarie.
Drew.
Um, ok
:P
I AM NOT SELLING IT DUE TO OTHER PEOPLE HAVING THE SAME CAR AS ME.. IT WOULDNT WORRY ME.. IM JUST SAYING IN MY AREA THERE IS SO MANY.. I LOVE EM DONT GET ME WRONG.. THE CAR I OWN I LEARNT TO DRIVE IN BACK WHEN I WAS 14 I LOVE IT, BUT I HAVE ALWAYS WANTED A 180..AND i WANT TO GET MY COROLLA BACK SO i'LL SELL THE SKYLINE AND BUY THE 180 AND AT THE SAME TIME BUY MY COROLLA BACK OFF MY MATE
Caps much!
Spotted many lines in the area again. They are all spreading. :(
you guys are a bunch of tools, hell forbid that anyone would want to sell their skyline
:ermm:
Ive spotted you, you doink!
Yea but that was you I know you already. I need random people to spot me!
Yeah, ok, in your first post you said you're selling it cause you see so many of them, but look, it doesnt bother me :ermm:
I was trying to point something out
Many Skylines today:
* Black r32 gts-t at tower bus bay. think it had a kit.
* Gunmetal Grey R32 gts-t with carbon fibre bonnet nice chromies (AUR---) @ Baulko
* a mum driving 4 door r32 gts-t with exhaust. Looked at me weird @ blacktown
* Silver r33 gts-t series 2 asian dude @ blacktown
* following a purple/black gold rims R33 GTR "GTR-02C" infront of nissan blacktown. Some dude honked at us because we were doing u turns at the end.. pfft... and no honk from you, sigh.
No waves or honks from any of them.. :laugh:
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
