mass, luisa has a supra now? haha how mad... Mabrooks :D
hahaha yeh thanks, she bought it bout 3 weeks ago... i saw u wen i was in it not long ago, i think last week, on the hume highway, i was heading towards liverpool u were going the otherway, i tried to get ur attention but u didnt realise it was me, coz of the supra lol....
hows the car man?
Edited by mass_iv
also i think i spotted abo bob today, dude i think u live near me... are ur plates ABO-60B ??? i leave in west ryde, i saw u turning right into bowden street off vic road i was in a red supra, i think i see ur car next door to my mates place I think???
Edited by Abo Bob
Haha spotted twice in a row. Yeah that's me Mass. Just took out the street name for safety but that's where I live. Most liners I see around the area don't wave so I've given up.
I think Winks gf - or should that be ex :D - lives right near there and T04GTR works around the corner of course.
And yes that was me in Annandale visiting a good mate of mine.
Spotted UN33EK on Saturday at Beacon Hill Maccas... Haven't seen that car in AGES!
Also spotted myself going 40km/hr through the monsoon last night trying not to go outside the two dotted white lines :D Rear tyres are like pancakes ~
I think Winks gf - or should that be ex :) - lives right near there and T04GTR works around the corner of course.
Oh and neither of you got my plates right. hehe. :D:(
aahhh sweet u live right next door to my mates place, hehehe cant believe i have never seen u there, im at my mates heaps lol... next time ill wave :D
HA HA. Ryde Skyliners represent. Perhaps we should have our own thread...campbletown got one.......
The campbelltown one counts for all of the south west subs eg; mac fields, glenfield, campbelltown, aspin, livo etc
hahahaah so that was YOU !!!
I was swearing my head off to my mate in the car when you did that
hehehe...its all good...
Im lucky it was raining otherwise I would have yelled out at you...hahaha which would have been embarrassing if you spotted me after that :)
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
