yes.. he was apparently there playing with all my new goodies :(
what were you doing there, mr? SPY!!!!!!!!!!!!!!!!!!
hahahaha i was just driving past... i do live near there u know :)
and i can guess wat he is getting done :O
Spotted white R32 GRR-32R in Chatswood
that's my mate's sister's car. (also a mate of 2gu - up. Neighbors ? also they work near each other.) her brother drives a black r32 gtr cya-32r
both plates bought by her
his old plates were gtr-900 which i saw on a gray r32 gtr on neale ave., cherrybrook 3 weeks after he sold it.
LOL i see them all the time.. I cant be stuffed posting it all the time.
Spotted about 20mins ago: MAR-55S on Flinders St Darlinghurst, as I was driving out of the Shell servo. (just filled up with 'V-Power Racing' fuel...oh yeah toocool.gif )
Yo!!! i beeped back man...
arx 51d "the beast" 33.
2pm
also a couple of 32's
old northern rd
Saw that ugly peice of shit too.. Gold rims, veilside kit.. Disgusting.
Did you by anychance see me? I don't think i saw any other cars then that 33.
saw 2 32's 1 grey with cf bonnet
the other 2 tone grey
i was in a friend's white falcon (xd?) red p's
Spotted 4 Skylines today:
Gunmetal R32 GT-R on Seven Hills Road, reg AYZ-something
White R34 GTt on Herewood Highway, Blacktown (too far to see the plates, looked really clean though).
Gunmetal R32 GTSt with kit in primer only, plates GTS-747 at Seven Hills shops.
Black R34 GTt with white speed-stripes heading up Station Rd heading towards Seven Hills.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
