spotted Sambo (kennedy) on Delhi Rd this morning, I beeped, waved, flashed my lights, went slow as hell and you still didn't have any idea I was there!!! lol
space cadet!
Were you driving a Skyline?? Last time I checked this was the Skyline spotted thread.
Spotted "R32" gunmetal 32 with hektic big ugly chromies on the front stockies on rear, kept coming up next to me and being sick with his bov and giving me the "fully sick stare" from the back window coz he leans back so far, next time stop trying to be so sick by blocking me out of the lane I need to use to turn you tool.
I spotted three asian guys in various skylines yesterday, waved to all three and got the kangaroo in headlights look back from them!? :) HUH-000 strikes again..
Rude bastards!
Spotted Yellow R34 today, plate MYLADI coming out of Yagoona KFC.
anyone noe who it is? sounded mean
I saw that one as well today when i was walking along woodville road waiting for my alarm and new speakers to get fitted.
Spotted HAYSEY!
atleast I think it was him.. looked like HAYSEY plates on a white r32
I was walking across the rod on Pacific Hwy at the lights where you were turning right onto pac hwy, was staring at ya to see if I recognized you but didnt notice the plates untill after your boosted by me
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
