Spotted a silver/grey R34 GT-T Coupe literally flying along parramatta rd just past the big set of lights with macca's and crispy cremes on the corner, it was going so fast I coulnd't even get the number plate but it was yellow and fully custom it said some word. It was around 12:50pm.
Also around the same time a White R33 was in the Reading Cinema's car park.
I was walking on the side of the rd.
Drew.
spotted racinx with his girlfriend at towers this arvo
spotted a gunmetal grey r32 gtst at towers this arvo also..
really? i didnt see you. or did i. cant remember
Spotted this afternoon
ESH-11S white R34 coupe on Castle Hill Road
and spotted ranicx on Epping Road behind me :D
are you stalking me as well? lol.. i usaly see your car when im running late for work, which is about half of the time :laugh:
are you stalking me as well? lol.. i usaly see your car when im running late for work, which is about half of the time :)
nah you wouldn't of saw me. you were just entering the bus bay and i was at the lights opposite you,
i didn't see you until the mrs pointed ya out.. you were wearing a blue hat i think :sick:
Drew.
If I were a betting man, I'd say that the silver R34 was 'LEGACY' - I felt like I was standing still when the the tool flew past me on the M4 late yesterday morn/early arvo, despite the fact that it was pissing down rain and I wasn't exactly going slowly when he passed me (I was sitting on the speed limit)...
Also spotted maroon R33 this morning on Fitzwilliam Rd - was quite surprised to see a mature lady driving it lol :)
spotted a white r32 gtr plates osaka driving on warringah freeway on the way into the city on saturday night. Also spotted a silver 33 turning onto adams street of forest way on sunday arvo i think the plates were maniac or something, Gave a wave !!!
Spotted a few lines at eastern creek open track day on saturday...black r34, 33 GTR (J** 666) and a black r32 GTR....
shame about the rain...
Made for some good sideways action though...
Also saw some floating around the skid pan...
Thats what it was. "Legacy"
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
