Spotted a neat purple cefiro with drift teks and nismo kit going up Warringah rd through Beacon Hill..
And a silver 180 with black roof and R33 GTR rims looked like a drifter.
Edited by phillb
Oh, I spotted a black 32GTR in hornsby - it was in a parents with prams parking spot...and it had p plates..........hope you had a pran.....
Dammit.. I have a GTR looking black skyline 32.. and i was in hornsby! some one friggin spot me
>> no i didn't park in no pram spot though... so prob wasnt me
Edited by chinkeboi
Yesterday arvo at Manly spotted a white R34 GTT coupe with black bonnet and yellow tailight covers!
I've seen this car a few times around Manly, dunno whats the go with those yellow taillight covers :laugh:
Spotted like 5 skylines going down beecroft rd this morning around 8:30, one included Wink he was beeing followed by a silver R33, the others were before him a white R33, maroon R32, black/grey R32.
spotted ETHOLL this morning!! cruising along! :rofl::P
yay! finaly been spoted.
i didnt know your car was back on the road already, sounds good though
white r33 would have been me heading to work. silver r33 would have beem moanie
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
