Spotted a neat purple cefiro with drift teks and nismo kit going up Warringah rd through Beacon Hill..
And a silver 180 with black roof and R33 GTR rims looked like a drifter.
Edited by phillb
Oh, I spotted a black 32GTR in hornsby - it was in a parents with prams parking spot...and it had p plates..........hope you had a pran.....
Dammit.. I have a GTR looking black skyline 32.. and i was in hornsby! some one friggin spot me
>> no i didn't park in no pram spot though... so prob wasnt me
Edited by chinkeboi
Yesterday arvo at Manly spotted a white R34 GTT coupe with black bonnet and yellow tailight covers!
I've seen this car a few times around Manly, dunno whats the go with those yellow taillight covers :laugh:
Spotted like 5 skylines going down beecroft rd this morning around 8:30, one included Wink he was beeing followed by a silver R33, the others were before him a white R33, maroon R32, black/grey R32.
spotted ETHOLL this morning!! cruising along! :rofl::P
yay! finaly been spoted.
i didnt know your car was back on the road already, sounds good though
white r33 would have been me heading to work. silver r33 would have beem moanie
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
