Spotted a white R33 in Cabramatta pulling into a servo, plates were AQI something.
Spotted 2 x black R32's like 2mins later on Cabramatta Rd. This was at about 6.30PM lastnyt.
yeah that happens a lot...
saw some guy in the backstreets of pymble cleaning what looked like a very schmick and new yellow R34... i drive that way every day and today was the first time i saw it...
doing it with a bucket too, thats dedication :P
Was spotted by a Silver R33 on beecroft rd just outside cheltenham high.. he flashed/waved i returned the wave but did not catch the plates and car didn't look familiar hopefully u will come on here and post up.
saw a white R33 OTH-011 i think at thornleigh maccas last night... had a skylines australia sticker on the rear window but have no idea who it was...
also saw a black R34 that looked very nice... completely standard, but still nice :)
HELLO TO YOU IF YOUR OUT THERE!
Hey mate...
That was me.
Love a good wave and flash
Spotted MARSSS today, turning off parramatta rd Burwood in the afternoon
hell yeah! spotted.. was yrs a 4 door??? cos i saw one when i was waiting at the lights
also spotted teh Sash on Oxford st
spotted "V8HNTR" silver 33, in the city, cruising with a 180... i was the white 33 with the powerplay stickers... Man it feels good to be able to drive again :) miss the little beast..
also had some fun with a 200 an evo and an M3, never new how quick those m3's are... gave me something to beat lol... :closedeyes:
