think it was me
i drive a stock gtr
you went up to the freeway
nice to be spotted :)
Yep up the F3 everyday for tailgating fun by red P platers :)
Car looks noice :P
Also spotted a white 33 (S2 wing) on the F3 last night between Wyong & ourimbah exits Southbond about 9.30pm lat night... couldn't quite catch up..just noticed the stove lights ;)
spotted wtf 33r last night i was in my mates forrester and u wouldnt run. soft hahaha
Yay my first Spotted!
Ah is that who it was! I was half asleep nor the mood, plus I'm not in a postision to lose my car and licence it means job gooooone! What was the poofy run against the TX3?
i spotted him on friday night at thornleigh maccas... i should have gone over and said hey but i was eating :P
I saw your car there too. should have come up! I dont bite ......................... (hard)
shoulda... but i make an ass of myself enough without jumping into the middle of a group going "WHO OWNS THAT PIECE OF SHIT!?"
saw 2 skylines today... two that i feel like mentioning at least... both in chatswood...
one a silver 34... plates ** ** ** something... another a red 33... plates ******... the only reason im mentioning them is cause they flashed back :(
GET SOME MEMORABLE PLATES FFS! i dunno who the f**k you are :rolleyes:
Edited by DRD-00F
Saw 2 jillion Skylines last night on the way to Heaseman's Suspension, then another 1 million (and their owners, and, finally, another Stagea :):(:rolleyes:) while there, then quite a large number of Skylines today.
spotted a black 33 with buddy club stickers on the side, near the start of the harbour bridge last night at around 6pm (give or take 20 mins), heading towards the city. Pretty sweet
caps lock Mikey :rofl:
916
I spotted a white 33 on pac hwy series 2 with fmic around lindfield- looked standard other than that.
was in the 31 - hence why u didnt see me :mellow:
