Anyone spot my car around the thronleigh area last night doing anything naughty? i loaned it to a mate of my brothers... just so happened to be the same mate that crashed my brothers car...
was shitting myself all night... :D
in all actualality, i said he could drive it down to my place (he lives half way up the road) not to indoor soccer...
I would have kicked his ass! :thanks:
That's Hempy from the Central Coast I believe, nice looking car that one.
Yep i know that, was seeing if he was checking this thread which he isnt :D
Hes so dropped - see central coast thread for details lol.
Spotted lanky71 coming down Kariong hill this morning....
didn't see you??
spotted maroon line with
GLT 00Y plates :)
on pac hwy @ 4:30 @ turramurra, I wave ,he wave.....
would have followed you but i like my licence too much
Thats Guiltoy, he is in the Central Coast thread.
GLT 00Y plates :)
that car is nuts i think u would of had trouble catching him
Spotted a wine red R32 GTSt at the KFC on the Cumberland H'way in Northmead around 2pm.
Spotted a dark blue V35 tonight, plates VGT350 or similar, and a silver R34 GTt (didn't catch the plates) following closely behind. They were both heading West on the Great Western H'way up around Blacktown or Prospect around 5.45pm. Not long after that I spotted another wine red R32 GTSt heading in the same direction, but this was up near where the M7 crosses over.
As I was leaving my friend's units in Werrington, I spotted a dark blue R32 sedan ;) with chromies :laugh: parked in the car park.
didn't see you??
That's because I am in the wrx... although how peeps can't hear it I have no idea ;)
I have waved at 11ty lines in the last week since driving "the other car" and not one wave :laugh:
If anyone sees a mad woman waving out of a white wrx wagon.... I am not nuts and its safe to wave back !
spotted r33 gts t Num plate WNA-RUN.... watta made c unt num plate lol....
i saw your brother at the petrol station i believe :blink:
Drives a WRX, said you had an R32, getting plates soon...
this was a couple weeks ago now, but he seems nice :w00t: you guys should come to a meet sometime...
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
