spotted heals of lines today!!!
Lanky again on beecroft rd... mr ethan heading my way on beecroft rd... white 33 gtr parked at an underground parking station in the city.. personalised plates and i can't remember what they are now!!! i parked next to you though :wave: also spotted a silver 34.. plates mz034 with a guy driiving! hehehe :wave:
There's a red r32 gtst 2 door hanging round burbank pl @ norwest....if your on here you may have seen me cos i have the dark blue 32 4 dr that works in burbank pl...i really wish someone would spot me..even if u just say u spotted me it'll make me feel better
i know its not a skyline, but blow me...
spotted a rather nice Supra on the way home yesterday... looked EXACTLY like my mates supra which scared the shit out of me cause its been in the shop for 9 months and i thought he was driving it to mine to show me...
nearly drove over the round about checking the plates to make sure :rofl:
i saw your brother at the petrol station i believe :)
Drives a WRX, said you had an R32, getting plates soon...
this was a couple weeks ago now, but he seems nice :banana: you guys should come to a meet sometime...
yea buddy he told me bout u.he said ur a nice guy.... yea i just got my car on d road today.. Takn it to the dyno for a dyno run.. fingers crossed everythingz ok..
and yeaaaa one day well meeet up go on a cruise or sumthing... :banana:))
was on sunnyholt rd around 1030ish
spotted a white r33 with 34gtt rims green plates in a car crash!
there were also a commondor and mirage i think.. hope no one was hurt
eeek. was worried then when you said white 33 with 34 gtt rims.. but Lizjane doesnt have her p plates ..*phew
That's what I was thinking too, Sammeh.
*phew, indeed!
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
