Yes i am from QLD, i was down in sydney for work this past week. and i spotted only one possible car, that was a Silver Stagea. em the road was a black one with with lines.... near the airport lol.
GO SYDNEY TRAFFIC....!!!
spotted a stagea at my work car park norwest - HGE ***. Nice AVS rims
lol must be the place to be spotted, thats twice in a week.
Didn't see your car there though? or did you get there early enough to park inside
hehe I get there at 8 so theres usually parking inside.
I didnt know it was your car and you worked there. what do you do there? i'm in office infra :)
I spotted a bayside blue R34 GTR a coupld of times in the city last week.
Also got flashed by a black R32 on Heathcote road yesterday. I think I flashed back but not sure if I pulled the lever hard enough.
Also saw the same white r33 3 times yesterday in various places. White guy driving, asian girl passenger. The first two times were unsurprising but to see them coming towards me again 3 or 4 hours later was a bit of a shock.
Hey Gengis, I'm running a project for logistics for the next few months...only started a few weeks ago :thumbsup: Is office infra part of IT? I'm dealing with a bunch of guys down there re prices atm.....
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
