on saturday i spotted liz at berowa,
yes i saw you follow but i could not wave looooooooong story.
damn I gota get sum good plates :(
because I have never met you but
as soon as i saw the plates at the lights I knew who you were
hahaha.. no problems
and everyone said that no one would get the plates with 22 instead of ZZ
losers.
Spotted a grey R33 coupe plates MY33RT driving on Warringah Rd last night, I know your a member but cant remember your sig.. I waved but you would have had no idea who it was ;)
Edited by phillb
You dirty little whore adam
Thanks love.
I spotted a nice yellow R34 going into the eastern distributor tonight after work. I was perving on your car, not your gf in case your were concerned. Had an SAU sticker and yellow number plates but can't remember them now. I rode my bike beside you for a short while.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
