spotted a red stagea around at leonards
That's probably StageIan - red series 2.
yeap spotted rick again today lunch time near north parra
And where have you been hiding, Albert?
Spotted a silver Corolla, a white WRX, a black Supra, a white R32 GTSt, a silver R33 GTSt, and a white R33 GTSt at Hornsby tonight...
Also spotted a white R33 GTSt four-door parked on the Pacific Highway in Hornsby on the way home...
spotted a hot light blue R33 with GTR kit doing deanies in albury, and just spotted a white 33 with the plates starting with AON also in albury
bahahahahahahaa
when we pass through Albury for DECA I'm going to do a deanie for old times sake! lol Good times! lol.
spotted some typical P plater in a silver r33 bouncing around on what looks to be stock suspension doing 160 plus with 4 people in it on the M5 last night. beautiful!
just army aye mon-fri
getting ready for apec too
been pretty busy lately
seen my wife JEss car at home and also kellys car Last night and also TO4 daves car last night and Doof's car MX5 last night
oh f**k you........... that thing got a flat on the way home too...
saw Liz on my travels today, she flashed me, then waved at me :thumbsup: she looked so happy to see me :thumbsup:
cheered me up :)
spotted a few lines tonight at wsid. one which i can rememeber was YB50FT a grey 32 gtst chick driving and dam she is hot. and also spotted nismo god.
damit that girl used to go uni with my in strathfield..never got a chance to meet the driver :thumbsup: but hey im that guy in the black and white skyline...i hope she's on the forums..
haha yeah.. Wakefield went off on Saturday.. or was that me going OFF wakefield lol
Haha Liz, I think you did a great job on Saturday :thumbsup: it shows you were pushing the limits of street tyres :thumbsup:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
