Spotted a Gun metal gray/ black?? 32 GTR 9am on burrows street alexandria had a sau sticker on the quater window.
Spotted AMY033 on gardeners road mascot.
spotted a white R34 GTR plates CUDERE (see u there? ) on princess h'way rockdale around 4:30 this afternoon
I spotted him last night at around 6ish on wattle street five dock!
i went to parramatta last nite from Norwest...spotted about 10 R33's...2 R34 gtt's....NO r32's!! not happy...also spotted various silvias...just out of curiosity..has anyone EVER spotted me?
Edited by NG0387
spotted a black 34 on the way to the city this morning
then a silver 33 on m2 on the way home this evening
Slim are your plates SL 32 IM or something? Because Im pretty sure I spotted either your car or someone similar .. Saw you racing up behind me in a 32 .. well I guess it was you .. Gave it a wave but dunno if they saw me..
:D
that would be me :D
didnt see the wave though
Saw a very nice black 33 in Ryde last nought around 81sh pulling onto ryde road... Had large decal writing on it, DCD or something like that... was an odd design and hard to read... looked clean though :D
spotted a 32 gtst on somerville road Hornsby Heights this arvo....
and spotted two home and away actors at the narrabeen sands - and got extremely drunk with them hahahaha
i know this is lame....but can u disclose which home and away actors u got sloshed with? just to name and shame basically
Spotted a R33 4 door on the f3 this morning around 7:15am heading towards sydney right at the end bit of the freeway just b4 it turns into 80kms speed zone - then 15secs later a highway patrol lights/siren a blazzing swerving in and out of traffic - hope he wasn't after you.
Then tonight on the way home on the f3 spotted a maroon R33 stock bodykit but had a exhaust can't recall number plates but see it almost every saturday night on the way home from work.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
