Spotted today in Hornsby Westfield carpark a black R34 rego: AWA32M, very nice!
A Silver R33 rego: CUTOOL (LOL) parked on Pacific Hwy turramurra
And a silver R34 rego: BAI33L with shopping list on the doors and a big nismo sticker on the rear windscreen.
just spotted a silver R34 GTR at crystal car was cafe blakehurst, plates BAY- ***, and a gun metal grey R32 GTR on princess h'way before tom uglys bridge with a chick driver, and a white R33 plates SUS-25T
spotted a few random skylines over the weekend to canberra and back and a ceffie?
*waits for mention*
Sif include the Ceffie and not me.... *chucks tanti* :action-smiley-069:
Spotted Evil spotting me this morning on the pac hwy.... :)
*EDITS* Thats better Chris!! lol
Pretty sure I saw this one. I was around Endeavour and she went past me. Blonde and looked pretty tidy :P Somewhere around 12-1?
spotted a few random skylines over the weekend to canberra and back and a sexy 200ZR and a ceffie! :)
*waits for mention*
Sif include the Ceffie and not me.... *chucks tanti* :D
Spotted Evil spotting me this morning on the pac hwy.... :(
'sif include the Ceffie and the 200ZR Fairlady, and not include me! *shakes fist*
Stagea spottings link are in my sig, Chris!
Pretty sure I saw this one. I was around Endeavour and she went past me. Blonde and looked pretty tidy :( Somewhere around 12-1?
yeh i think it was around 1:30ish or sumfin
spotted around lunchtime on Victroia rd balmain white R33 gtr plates SAU-97R, then on new canterbury rd a white stagea plates UFO-88B, and this afternoon a wingless yellow R33 plates aug-*** (security ? )
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
