DEV 10S (black 32) in Hornsby just now, a Stagea at Pymble Prestige smash (in Hornsby) and a 34 also in hornsby driving past the station...
got a mean look from the 32, nothing from the stagea (being IN the shop, thats to be expected), and a wave from the 34... but i think he was thinking wtf for a while...
Doof, what colour was the Stagea please???
Pretty sure i spotted some of you fellas last night... and a lass :(
Though i don't think I properly introduced myself...
;) sowwy if i didn't... I'll give you a BIG scary hug next time i see you :)
Just saw a black 32 GTR with yellow plates... passanger was looking back, i flashed lights but dunno if you saw... passanger looked familiar too ;)
Adorra - adoraa however you spell it... Hi bish :)
Spotted Grey 33 4door (with space saver on the rear)today in Newcastle, driver pointed at our car (grey 32 4dr), and spotted also Silver R33 GTR heading towards charlestown.
I should post here more often as I own a skyline myself :P
spotted more skylines than I could count on both hands within a space of 15 minutes... r33's and r32's all around dural, castle hill and baulkham hills..
oh.. and one sexy midnight purple 2 R34 GTR VSPEC.. mmmm sexy car Mass :(
