Spotted a white series 2 R33 on Pennant Hills Rd this afternoon, rego: BAS***
Oh and spotted Sam, Greg(vspec) and JDS Racing(again) cruising past the Marina on Mc Carrs Creek after I'd been on a boat cruise :)
Edited by Zilch*
Haha spotted zilch when sam and i were on the way to palm beach, and spotted a black 32 honk as they went past as we swapped cars
And where was my call.....hmmmmm ? ? ?
Soooooo dropped....... :)
Spotted a white 34 Gt-t yesterday arvo at Chatswood and a couple of Silver V35's ..... bout 6ish
We just wanted to drive eachothers cars and one thing led to another and we ended up at palm beach. . . . . i swear. ;)
We just wanted to drive each other and one thing led to another and we ended up at palm beach. . . . . i swear. ;)
Fixed :)
Hmmmm well, il have teh 33 on Saturday soooo early next week????
Spotted Silver R32 with chrome tint on Pittwater rd tonight around 6:30pm heading north through Dee Why :banana: and a cream R32 4dr being a nub "hooning" around Warringah Mall carpark tonight :):blink:
Edited by phillb
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
