Spotted A Maroon 33 GTR give it a bit of a boot up Lyons Road Five dock this morning at about 7.50am. Tsk Tsk Plates were GTR 095
used to spot that car all the time in west pennant hills
Spotted Ando's old Ceffy on Fullers Rd last night bout 7ish..... We were the group walking and yelling "hey thats...... oh wait no its not" lol
I'd say that would be Dead32 enjoying his new ride...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
