Spotted a GT350 Skyline V35 (blue) with SAU stickers in ryde to homebush then you turned onto m4.. Plates ???-50V or somthing.
Have to say car sounds great, was in a Accent drueling over your ride
Thanks Dude,
gotta love that fuijitsubo exhaust, quite as hell when cruising, but nice note when you give it a tap.
Spotted a big white Nissan Patrol 4WD flashing and waving at me just off castle hill road about 2mins ago.
I kinda nodded. Wasn't sure what to do actually. Who was it?
:D if you're on here.
:cheers:
hahaa
Dj Albert was my old username lol, it was lame and more lameness so i changed it LOL
but sheng its me :cheers: but im still albert, call me wateves GET IT :D
welllll the white one next to me was a tool, had like 10 woofer run out of 1 one channel amp, and the dude was looking through a crookerd rearvison mirror
...mm must be the subs
youll always be SCHNEGGLES to me boy!
I love having a unspottable euro rocket lol
I always see a white r33 parked near the sports field next to Eastgardens in sydney when I drive to work
Also saw a green 400r kitted r33 on blaxland st in matraville a few months back
I see that White 33 there all the time.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
