Spotted a GT350 Skyline V35 (blue) with SAU stickers in ryde to homebush then you turned onto m4.. Plates ???-50V or somthing.
Have to say car sounds great, was in a Accent drueling over your ride
Thanks Dude,
gotta love that fuijitsubo exhaust, quite as hell when cruising, but nice note when you give it a tap.
Spotted a big white Nissan Patrol 4WD flashing and waving at me just off castle hill road about 2mins ago.
I kinda nodded. Wasn't sure what to do actually. Who was it?
:D if you're on here.
:cheers:
hahaa
Dj Albert was my old username lol, it was lame and more lameness so i changed it LOL
but sheng its me :cheers: but im still albert, call me wateves GET IT :D
welllll the white one next to me was a tool, had like 10 woofer run out of 1 one channel amp, and the dude was looking through a crookerd rearvison mirror
...mm must be the subs
youll always be SCHNEGGLES to me boy!
I love having a unspottable euro rocket lol
I always see a white r33 parked near the sports field next to Eastgardens in sydney when I drive to work
Also saw a green 400r kitted r33 on blaxland st in matraville a few months back
I see that White 33 there all the time.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
