Spotted a few Skylines yesterday.. the ones I remember
- R33 coupe GTS2NV in Willoughby
- R33 coupe FSN8TN (or something like that)
- Black R32 coupe FAT-32R in city
- R34 GTR on Willoughby Road in the arvo (can't remeber the plate though).
All around 6:45pm, waved at a guy in a gunmetal R32 GTR on Pac Hwy between Mt Kuringai and Berowra, then another gunmetal R32 waiting to turn over the bridge at the lights in Mt Colah and spotted a black 200ZR in the Mt Colah Maccas drive thru (Anna?) :D
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
