Spotted a p plater in a silver R34 cutting me off without indicating then swerving into an exit lane (also without indicating) going towards Maitland. Not a good way to make friends.
All on my way to work this morning,
silver Stagea in chatswood, northbound
silver R33 'Sqiish' in Ultimo wth sau stickers on the windows
and gunmetal series 1 R33 next to my work wit a disability label thingo;)
spotted jon yesterday arvo and i know u spotted me hahah
Haha yep, definitely spotted ya! Arm out the window :D
Spotted a Silver R32 GTR on Castle Hill Rd on Saturday near the middle of the day... He flashed me but my g/f was driving so I couldnt flash back (I asked her to flash but she said I needed to get a few drinks into her first!) :O
All around 6:45pm, waved at a guy in a gunmetal R32 GTR on Pac Hwy between Mt Kuringai and Berowra, then another gunmetal R32 waiting to turn over the bridge at the lights in Mt Colah and spotted a black 200ZR in the Mt Colah Maccas drive thru (Anna?) :D
it was me @ mt colah lights
i waved u waved
what r u doing tomorrow nite?
come out for a meet @ P6,
sounds huge
Spotted a few lines today.
-Silver R33 GTST with exhaust, HKS power sticker on rear bumper, p plates- spotted on Narellan Road, Campbelltown. I was next to you as we turned right at the lights.
-White R32 GTST, being followed by another silver R33 GTST- spotted near Picton
I spot many a skylines parked in my street of an arvo after work... dunno why...
If you go to North Shore gym, or work in Bridge st Pymble... HAI! :P
AQD38T - grey 33
a grey 32 all the time
white 33 GTR INHEVN or something... might have plates mixed up...
:P
squish is Smasha.
I iz famouzz
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
