spotted black r33 with a veilside front bar coming the other way crossing the speed camera bit the same time as me on arterial rd st ives yesterday about 1pm. can't remember the plates, was too busy checking my speedo ;)
Saw a silver R34 turning off pacific highway yesterday around 4.30pm in chatswood. (Brendan? Im pretty sure it was you :blush:) shortly after tht a silver series2 R33 in pymble and a white one in wharoonga :banana:
And this morning there was a silver 4-door R34 in Hornsby..i think nbr plate was Homiee or somthin like it :banana:
Spotted a few today. 5:20pm on monavale rd near St Ives, waiting at the lights,a white R33 with GTR wing and white starcorp impuls(primordial?) 5:40pm a black R33 with GTR wing on the Pac Hwy at Mt Colah, waved and he waved back :blush: and then 5:45pm in Berowra a gunmetal R32(GTR?) who also waved back :banana:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
