i parked behind a hot white R34 which i think had a URAS kit on it in some street right next to the enmore theatre last night....went and saw the new young pony club...pretty rocking gig!
Went up the Putty Road to Singleton and back yesterday... saw "321 GO" R32 and a R34 GTR..
Was it a silver R34 GTR? - If so it was me! Thanks for the wave Tommo - hope you had as much fun as I did! Home in one piece - license intact and grin from ear to ear. Doesn't get much better.
regards
Andrew
Spotted last night, a Maroon R32, Nicely modified, with the plates "BEM12N i think .... Shell Servo on Parra Road, sumwhere after the M4 ends.
That was a crazy sounding launch you did.. lol
Also, a 32 GTR in the maccas next to BP on parra road around 2am : Plates: "2HYPO"
In the same BP, also spotted, a Orangish brown 33 GTSt : Plates: NI5-5KY or sumthing like that.
:D
Yes it was me this morning! :woot:
ZZW-30R are my plates.
Also spotted LAMBOS white R33 coupe on Warringah Road
Spotted Primordial again parked in Cherrybrook!
Also spotted a red S2 Stagea AYQ-25Q on Epping Road.
Haha, i thought so! :D
that would have been me :P
Spotted White r33 gtr (agz87d) parked next to me at fox studios on friday night wit sau stickers. I was walking towards my car and i thought whoaaaa someone swapped my 32 t for a 33gtr sick!!!!! But alas my old girl was sulking in the corner next to its big Brother!!!! :P
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
