Spotted a silver 33 not sure if it was a GTR it had too many after market body parts on it.. gave him a wave and I got a funny look back. This was this morning over the Gladesville bridge (Victoria rd) at about 8.20am
Oh I also saw a really hot Dark blue 31 GTS with a big fat FMIC on Centennial Ave Lane Cove this morning at about 8.35
Spotted in Chatswood a white R33, asian chap driving I waved but nothing back :P
And spotted Mitch(Mr Moo) following me home :P
did see you at kfc, then you cought up, but the work van just couldn't keep up :rofl:
hahaha! I thought it was Haysey!
Sly work with the camera when I was sitting at Mangrove waiting on the C&I Cardigan Club to catch up. :cool:
Who was that guy that did his front end in just up from the pub?
hahahahahaha blue flame drive by twice lolz
one of the guys had a bit of a skid, nothing too major, he could move it and what not.. just a bummer it happened on the cruise... coulda been worse!
Spotted TJ...........'s old GTR :D
so that means I spotted Matt! Hai!!!
Sorry my head was elsewhere and I was completely not thinking (heading to the hospital) - hence looking at you like "who the f**k is that?"
I'll be more social next time :D
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
