Hey Albert, what's been going on?
Haven't seen you since the ns.com Northmead meet.
- Sam
Hey not much aye, just bumming + uni lol..
Well welcome to the club and check out my hill meet up in the event section :)
Spotted "SLO.32T" R32 parked at High st Penrith tonight, and a silver R33 on Kissing Point Rd near Dundas,
and also a silver R32 GTR getting inspected by HWP near the M7 turn off in Glenwood
Spotted a white R34 GTR on sunnyholt rd plate were "BMM" or something,
Also spotted "SL33KY" i think White S1 R33 pulling out Wollies headquarters in Norwest this arvo.
That was not me Albert lol... Maybe someone has a numberplate like mine around! I also spotted last night near Ripples/Woolies in St Marys a black R34 GTT, looked tidy.
spotted at bout 6:30 yesty a grey R32 on ummmm i think kissing point road at the lights with me (dun go 2 sydney much :O haha)
then at 9:00 on i think is it the cumberland highway or pennant hills road bahhh or sumtin like that lmao! a white N/A R34 with green Ps... was that u Aron??????????
What! No wai ahah!
Was a chick driving it too!
Are you the owner of the black 34 I see there sometimes?
Yeah sorta :O
you playing summer league up there mate?
i was out last night but i was in the castle hill area and rouse hill area? - you sure u saw it in cumbln or peno? - I wudnt imagn ther are 2 many white N/a r34 with green p plates :D - did they have blue number plates with Nismo sticker on the front Windscreen?
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
