at carlingford road tonight at 7:20 there was 3 R33's in a row waiting at the traffic lights approaching Pennant Hills road, me, a white r33 series one in the middle, and another silver on the other side, pretty cool sight.... too bad the white r33 guy drove like a douche accelerating all the time while he should really just be cruising.... he looked angry and all that, looks like somebody had just as shitty day as me, atleast his car was in good nick
I work just around the corner from there in the Alfa workshop!!
there is also a very nice silver kitted R34 gtt that parks there!
Yeah that 34 is very nice. Used to see it there all the time.
I work up at mazda now around the corner. Small world!
Ahh euro cars!! U know chris in the workshop...lives up at gosford way!!
Spotted a silver 34 in the army barracks at moorebank tonight, have seen it their quite a bit actually.
mm what you doing there lol..
Spotted a gold R32 GTR in penrith tonight, plates were "AXN.03Q"
and
a Gun grey R32 Gtst on sunnyholt rd, plates were" AJ.96.LI"
and
lol my mates in the army he lives on base their im usually their once a week or so
spotted mr GOLDZILLA in his stagea at pennant hills heading north bound past boundary road at about 7:20ish tonight
Oh, I didn't see you Tom, were you in stealth mode in some other car?
nope i was in the line with the lights on, i don't know how you missed the back of the car (looks like an electric stove top), you drove right next to me lol..... i guess their was traffic and you were approaching the traffic lights and their were trucks around aswell, i guess you were doing what we all should be doing and actually paying attention to the roads lol
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
