just spotted a guy in a white 34 near sevenhills. I waved from the passenger seat my misses is driving cause im pissed. Only the second time she has driven my baby. She rocks. Treats her like its her own love you baby.. Anyway you beeped :-) woo hoo. Back to giving directions now. :-)
friday spotted guilt toy turning off edgeworth david ave in waitara - was driving my mates commodore, gave a toot but was too stealthy
then saturday spotted zilch at the lights at mt kuringai - again, stealth mode but in 323 and then an hour later in traffic on pac highway spotted smasha! stealth mode once more in the failbird!!
well, I spotted you tonight!!! and I *should* have spotted you yesterday but the taxi you were in didnt reverse back!!!
and spotted clappa driving so called taxi!!!
and then tonight I spotted ando n jess n S A M n clappa n anna n dave n myself at teh northern yay!
Lol, honk next time Chris :)
I spotted and parked next to a white R33 GTSt when I went to the shops at Winston Hills earlier. Also, just after I left there I spotted a black R33 GTSt turning right off Powers Road and onto Old Windsor Road in Seven Hills.
Spotted the same white R33 today again at Winston Hills shops.
lol! spotted dif cruising past traffic :rofl: wish the sky could squish to bike size!!
:laugh:
Just buy the same bike lol.. it still has the round twin tail lights so it's kinda like a mini Skyline plus it is Japanese too! wooo
spotted a white r34 on old northern road last night around 11:20pm
I hope the car in front of you with the stupid chick standing out of the sun roof while going 80k's wasn't with you... idiots.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
