spotted a White R34 on Oxford street at about 2am sunday morning, had Skylinesaustralia.com stickers front and back and had red and white number plates
also saturday night drove with a guy down james ruse drive and windsor road for 10 mins in a black non turbo auto R34 that was riced out with decals and body kit
alright who was the guy that i drove past TWICE tonight with the white r34 gtt 2000> model - 1st on glenhaven rd and then on the round-about at new line rd and boundary road??? - btw your xenons sting the eyes!! - i was driving my white r34 with green p plates
man i was looking for you! were you in stealth mode?
I saw a skyline of some sort drive past me as I was about to go past the RAAF base at about 1am this morning on the way home
might have been me -black 33 with big sau sticker on back window?
spotted gtr sean this morning heading towards the maccas in mcgraths hill. gave you a wave but i think you had your mind set on a bigmac
Ha ha didn't see ya, I'm in my own little world!
Yeah, spotted Fordy31 in Richmond getting out of the beast the other day.
drove down pennant hills road with a white R33 gtst at midnight tonight, we had a little winge about the high number of cops on the road around carlingford....
Spotted a black R33 series 2 parked at McDonalds near the Airport.
and a black R32 on pac highway in atarmon driving into chatswood.
What time you see the black 32? Might've been me or roadworia.
Also what car were you in....I spotted heaps of skylines on my way home but forgot details :P
hmm....must've been between 5.30pm and 6pm i think :)
I was in a black R33.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
