spotted a White R34 on Oxford street at about 2am sunday morning, had Skylinesaustralia.com stickers front and back and had red and white number plates
also saturday night drove with a guy down james ruse drive and windsor road for 10 mins in a black non turbo auto R34 that was riced out with decals and body kit
alright who was the guy that i drove past TWICE tonight with the white r34 gtt 2000> model - 1st on glenhaven rd and then on the round-about at new line rd and boundary road??? - btw your xenons sting the eyes!! - i was driving my white r34 with green p plates
man i was looking for you! were you in stealth mode?
I saw a skyline of some sort drive past me as I was about to go past the RAAF base at about 1am this morning on the way home
might have been me -black 33 with big sau sticker on back window?
spotted gtr sean this morning heading towards the maccas in mcgraths hill. gave you a wave but i think you had your mind set on a bigmac
Ha ha didn't see ya, I'm in my own little world!
Yeah, spotted Fordy31 in Richmond getting out of the beast the other day.
drove down pennant hills road with a white R33 gtst at midnight tonight, we had a little winge about the high number of cops on the road around carlingford....
Spotted a black R33 series 2 parked at McDonalds near the Airport.
and a black R32 on pac highway in atarmon driving into chatswood.
What time you see the black 32? Might've been me or roadworia.
Also what car were you in....I spotted heaps of skylines on my way home but forgot details :P
hmm....must've been between 5.30pm and 6pm i think :)
I was in a black R33.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
