spotted a bayside blue r34 gtr number plate SIANA at woodville rd at 345 hooning it past me before a school zone and in peak hour traffic. was thinking nice car then was thinking idiot..
Edited by 5hu7o
Spotted a white G35 badged as an Infinity with nice black Rims a few days ago, on wednesday around 1:15pm going down George street. Plates were TokioG
That would be Tokyo Geoff.
Spotted nIsMo86 yesterday afternoon parked in his car on chaplin drive lane cove west. Sneaky sneaky..
You didnt spot me in my car cause my car has a blown motor lol...although i was in the area the day you speak of.
I think you spotted roadworia meeting me. I was in the rolla :worship:
sorry for a late spot, but i spotted CLICK on saturday arvo on silverwater road near kissingpoint, i'm pretty sure it was him, still has the pink stripes on the bonnet lol Can't see if he waved or not, i think his tints are contraversial lol, I love that car looks smick
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
