some one waved at me in Artarmon.. but they were in a ute.. from here?
Was it me?
That's because you look like every other temporary Australian riding a pink CBR lol!
:P
Says you homos!
You didnt spot me in my car cause my car has a blown motor lol...although i was in the area the day you speak of.
I think you spotted roadworia meeting me. I was in the rolla :)
DAMIT!
Yea the rolla was there too.. I zoomed past on my bike
Spotted two 33s crossing pacific highway in chatswood. Just after each other first one was white, second one black...second one might've been a gtr. cudnt se properly was too far away :banana:
Spotted a nice Midnight purple (maybe darker custom colour) on Pacific highway Artarmon travelling city bound across the road from KFC. Had my vehicle parked across the road at the time, fairly sure he stomped the brakes on notice of my car.
Licence plates had R32 somewhere it looked almost as Shmick as my ride!
spotted albert on cumberland highway just before the great western yesterday afternoon, lucky he beeped!
Saw Sams 32 parked at parramatta westfields 20 minutes later
Christmas day spotted a blue r33 gtst at macquarie park around 6pm
1x silver r33 gtst in north pymble around 6:15pm.
Today spotted a black r33 gtst s2 at Hornsby around 8:10am.
Also a white r34 gtt same time.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
