Spotted two lines today.
One black R33 gtst with gtr wing and green p plates outside maccas in waitara. If ur on here, pm me cuz i've got a few questions about ur ride :banana: Number plate was BHZ**Z
the other one i only got a quick glimpse at, was a gunmetal grey R32 on grosvenor road stopped next to the roundabout.
Spotted a silver 33 with an SAU sticker on the side window yesterday,... I think the plates were MAX 007
tonight also spotted a yellow 34 with front mount coming off a bridge near the chinese gardens.
where are all the skylines / imports in Sydney... they seem hard to spot,.. especially compared to adelaide
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
