spotted a white 4 door R34 GT-t in Avoca beach on Sunday
also spotted a black 33 XTC25T yesterday somewhere..can't remember where i was..somewhere in the hills area lol
Edited by Black Widow
ooh that would've grinded my gears,
you know what's a similar feeling...
I'm a guitarist, and it really sh$ts me when I see actors on the telly pretending to play while they lay over a recording and when the show takes it further, tries to make look "real" by making them move their hands up and down :whistling:
It's NOT a FARKIN GTR and THEY'RE NOT really playing!!! :D:):no:
or when they play piano they never show the hands :D
or when they fly a spaceship and they dont actually know how to
or when they....
I think it's called acting guys :)
it's a completely different thing mang :/ , how many people do you know own and operate a spaceship?
but yeah a small thing but still bugs me
it's a completely different thing mang :) , how many people do you know own and operate a spaceship?
I used to, but constantly travelling through the space-time continuum plays major havoc on your body, so I gave it up, sold the spaceship, bought a Stagea, and have more fun with less body-clock issues!
Spotted a maroon R32 GTR on Old Windsor Road heading towards Rouse Hill. Had an SAU sticker in the rear quarter window, and was bellowing black smoke out the back.
Spotted your Blue? supra, nice car.
Ha ha that was me, running rich on boost and the clutch was dying, so revs were going up, speedo wasn't lol!
Yeah, that was me. Thanks!
I was sitting there telling my missus that there was something wrong with it, on top of running stupidly rich. She just thought it was a shitbox. Sigh.. Women.
Yeah my missus thinks that tuned cars (not kingswoods) that blow black smoke are shitboxes about to blow up. She tried to get me to buy a micra (shivers down spine). Over my dead body.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
