Spotted a silver R34 parked on the street near Blacktown TAFE this afternoon around 2.15pm - had 4WD ride height and wheels that I wouldn't exactly say suited the car. :thumbsup::D
haha i know that one! its pretty ewwww
Hey guys,
I just recently bought a S2 R33, and its amazing how many other skyline owners give you the thumbs up / wave when you see them on the road.
I spotted a Bayside Blue R34 GTR "GTR70Y" in Narrabeen a few days ago, and also saw a Silver R33 S2 turning at Collaroy. Cheers to both of em for the thumbs up!
Hey guys,
Welcome buddy!
spotted a silver R33 S2 just now on norwest blvd
apparently mum spotted a new r35 gtr in parramatta hooning around almost collected her... it was black thats all she got.
Tonight on way home from work spotted liz 180sx in epping and a grey r33 coupe parked.
Spotted SAM916 on the F3 this arvo.. i was the one in the black hyundai accent beeping at u.. had andrew (qantas) in the back trying to wave at u!!
haha he told me about that, had the music up and i was in my own oblivious "i'm still waking up" world!
hehe check out all the skylines I spotted on the Putty Road Cruise.
Putty Rd Cruise Video
typical, I orgsanise the damn day and I get about 2 seconds screen time!!!
hahaah nah jsut kidding, awesome work mate..love the bit where it slows down as the lines pass you going the other way on putty road haha. wicked work!
spootedthe poor slim mobile with dead battery, poor blue bird couldnt revive teh 32!
it's alive!!! with a new battery...
spotted lots of skylines between epping and penrith and back via the m4
heyyo... i didn't see you anywhere!
spotted dave074 in middle dural today! :D I was off to Wisemans Ferry for a quick drive!
Spotted a silver V35 heading north on Old Windsor Road lat night while I was waiting to turn off Fitzwilliam Road in Toongabbie, then moments later spotted a black R34 going the other way...
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
