now spotted twice, blue bnr34 "34VSPEC". he's waived at me both times, im wondering if he'll let me drive his car now :headspin:
in the city the other night, "HPI-34T" - not ben ellis, but another guy who works at the same publishing company as him - was quite a buzz cruising down george st. with him too :D
hmmm....did I see kinks in a 31 today??? :confused: thought you had a pulsar Geoff??
Haha yes you did see me in a 31.. :D
still have the pulsar, but it's the backup / sister's car... :)
I was napping a bit waiting for a gap in the traffic, didn't realise it was you until you were already swinging past.
Cheers B-Man.. :)
I've seen that one too (on Parra rd). I'd pass up a blowie just to see it go by a few times in a row.
heh...
i saw a midnite purple BNR34 tonite at OzTag - "UGLY" apparently Ugly Phil from 2dayfm's old car...AND a silver EVO6 GSR(? didnt quite see the front or was close enough to see the rear stickers :D)
I keep seeing a Skyline Gts25t in West Ryde, nice silver stocky looking one plates Nizoom then ran into her at the bank but didnt say anything :D
and me and my Mate Craved have bone seen a Black R32 in castle Hill/Baulkham Hills on Old Northorn Rd and Windsor Rd , who have waved at us but dont know who it is, I can understand Craved getting a wave, but I wasnt even in a skyline so I have no idea whats happening there ..
I saw a blond chick in a nice black 33 on Alison rd yesterday, waved and got a dirty in return. I should have said, "I was trying to pick your car up, not you," but the lights changed and I was too slow.
Story of my life!
Story of my life!
gold! can I borrow that response!
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
