Mint as Stagea drove past me as I was backing out of my driveway, I hate Stagea's but this one I fcuking likey, if your on here I was backing out in my white r34 gtt, ohhh and also wanted to ask if the guy with the silver r34 gtt that lives in Rockdale on here, he lives just down the road from my mrs place, thanks.
Skylines are out to play today...
Silver GTT parked next to my temporary shit box burnt me a little bit inside:
And then this:
And a Silver 32 heading citybound on Wattle St at the intersection of GWH/Parramatta Rd.
And then this:
I'd recognise that rear bar & two-tone paint combo anyday, that's my old R33! Good to see it's still getting around
It's a series 1 but I put the S2 wing on it & that bodykit
ahh the memories... got my first blowie in that car too :w00t:
I'd hate to be that owner.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
