Saw nice burgundy R33, had a front mount intercooler passing the opposite way over the bridge at eastwood station (Rutledge St). Got a nod and i nodded back. yahoo! improved my rather shi*ty day somewhat
saw GTR032 @ a roudabout...olive st and quarry road, near midway shops, 930/945 this morning....nice ride mate
Thanx mate, I'm working at the building site at Eastwood public school and drove down to get something to eat..had the apprentice with me too, he's a GTR virgin hehe.
Jono
today i saw 4 skylines :)
The first 2 i saw were in Penrith Plaza.
It was a white HR31 GTSX. It attracted the attention of all the people that passed to go into the plaza.
Next i saw a DR30 Skyline ( 2.4L ) which parked next to it. The driver and passanger got out had a look at the GTSX. It looked like they had never seen a r31 coupe before.
After that my dad and I went to St Marys. As we were going we saw a Black R33 GTST just on Parker St/Northern Rd, just after Dunheved Rd ( it was heading towards High St ).
Then when we ame back we went to Bunnings in Penrith to look at ladders and we saw a Gunmetal Grey R32 GTST with the plates [LOO * LOO] next to Dick Smith Power House
saw MIS33R up windsor way....did see the owner though!
Also saw a black 33 on windsor rd....the guy didn't acknowledge me at all...but later he was in the left lane, and the lane was ending...and he thought his car was fast enough to get in front of the car in the middle lane....it wasn't....and he almost caused an accident......
Saw my 2nd 4 door line today, sort of silvery white 33 (must be a standard colour cos the other one was that colour too) through surry hills onto anzac parade. I drove next to him for about a minute before he noticed me but got the wave.
whilst having lunch in the city today I saw:
- Grey Just Jap R33 GTR - just jap stickers all over it.. is their Targa Tasmania car maybe??
- Bright Orange R33 GTR - Again I think it's a Just Jap car?
- White R33 GTR N1 race car with plates GTR N1
And on my way home a Silver R33 GTsT @ Strathfield Car Radio's in Artarmon ANC 14K
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
