Guest barbie iz a bitch
SPOTTED ON FRIDAY NITE... 'JTCOOL' r33 white on Parramatta Rd- 'WATEVR' silver r32 also on Parramatta Rd- white GTST, standard plates, fully smashed rear end! in Newtown.
LOL the JTCOOL was silver r33 and WATEVR was the white r32..
Spotted : Bright Yellow line, just coming out of Syd this morning, to busy staring at it to read the plate ;-) (Lovley exhaust note - Must have been a GTR, but was drooling)
(I drove down from Bathurst this morning, so came across plenty of lines, and any that I didn't wave to, I was inspecting ;-) )
(If anyone saw me on the way, I was in a '96 Silver GTST, Reg: ZebHax - http://212.42.1.197/Zeb/line/line.jpg)
Just saw 'CRAVED' driving past dural golf range...
Im finally back on the road too  :D yippee :D
hey, must have missed you... in my own little world on the way to work..
plus i was practicing my left foot braking --- needs work :rofl:
Saw a white 4 door 34 parked on oxford st yesterday arvo...around 2ish! thought it might have been ABO BOB....but i didn't see the plates :D
Yup that was me. Yay, I got spotted again! What colour are you Moanie? S1 or S2? I think my gf spotted you. She is getting pretty good at spotting now. She's got 32, 33, 34 down as well as 33 S1 and 33 S2 but I don't think even I can do 1.5 at a glance.
hehehehe...i thought so!! you're the only 4 door 34 i know of in that area! :D i wanted to do a u-ey and do another driveby for a better look but we were running late, and i'd have gotten yelled at! :
Mines a silver s2 :) hehehehe...you chickie needs to herself a line!! :) :) :D
1.5?
Mines a silver s2 :( hehehehe...you chickie needs to herself a line!! :) :) :)
1.5?
Yeah series 1.5 has bits of both. I'm no expert on it though. Skylineboy could probably help us out.
yeh I've seen TTL before
Gorgeous car! nice turbo too :(
Yeah that's the one. It belongs to a friend at work.
He showed me the car the other night and the thing sounds like a rotary with all the work he has had done to it. He's gonna take me for a spin once he gets some new rubber on the back cause he can't get the 500HP to the ground :D.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
