I almost hit into a fellow R34 (blue) at North Sydney in Walker st. today. I thought the amber lights were on because it looked like a guy had just locked the car and was walking away from it. Turned out it was his right indicator :P
Anyway, nice ride whoever's it was!
Yeah, was that you in the silver 33?
Nice car.
That lane is always slow :P everyone turning right.
Yeah was on my way back after dropping the kids off to school. Today was not to bad, other morning it takes 15-20 min to turn there.
Also spotted a silver R33 turning left after the White R34 on James Ruse Drive but not before spotting a wine red R33 on Gt Western Hwy near Pitt St heading into Parra
Spotted!! black 32 GTR GODZLA on f3 this morning heading north,didnt get to see much as after i pulled up to say gday he showed me GTR power and dropped to 4th hehe nice car!
I havent got my membership package yet so i cant show off my skylines australia sticker =[
keep seeing a bright orange r32 gtst in a workshop in Kingswood ( penrith area ) near the Cemetary.
That place usually has a few nice cars in it, old mustangs, i think a ford xr6 turbo - lots of sponsor stickers.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
