I just saw a pearl white R34 GTR M Spec drive past the shop in Drummoyne. ATW-### I think???
I drive past there all the time, i'm surpised you haven't seen me before.
She is fillthy dirty , usualy she is spotless.
Spotted: My sorry ass without a sky.
I really miss my 33 gtr :(
I really want another one, but im not sure what to do. I only have 12-15k atm and want something to drive around in. :D But want to save up for another 32/33 gtr
I miss my old car, she is my love (L)
What do people suggest?
my gtr is broken..
get a clean 32 gtst - they work.
I presume a shitbox = 32 or 33 gts-t ?
gtr's are shit
:werd: rukus
spotted mass_iv, Shonen, rukus and Beer Baron today
I had a nightmare like that once to.
Moanie, if you see Kel again can you say Hi from me? and ask how the kids are?
I thought it would have been you... only know of 1 other Pearl White M Spec in Sydney and I know the owner quite well "GTRPWR"
Yeah it was filthy.. haha you should have stopped past the car wash down the road :angry: Looked like quite a nasty exhaust stain up the rear bumper bar too
And yes I have seen you a few times before :O
I know of the other pearl M-Spec , i spoke to the owner a long time ago ( 12months?) at a set of traffic lights if i remember right his name is Omar, as far as i know they are the only 2 M-specs in Sydney.
Its usualy very clean but with all the rain we had, i thought there is no point in washing it.
dhc always gets spotted!
Is it really loud yet?
your just jealous wilbur :angry:
and NO its not arrived yet....f**kers f**ked me around.....they waited until I called them to tell me that they have run out of stock in Japan and they now have to MAKE it.....another month :O
Spotted a white 33 in Buladelah yesterday at about 4.30
I would have looked really strange, coz I was leaning forward pulling up the tounge in my shoe when I spotted you and waved, so I probably looked about 3 feet tall :angry:
Edited by Lazy-Bastard
That's him Omar.
AFAIK there are only 2 as well.
Guest
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
