Spotted 2 lines on my way home from work today.
Silver R33 parked on Herbert St in St Leonards with plates: BFG-05Q (green P plater)
Black R33 heading towards Chatswood Chase on Victoria Avenue with plates: XBT-273 (I think).
Both looked pretty nice :>
spotted a hot lookin 34 yesterday at norwest, plates were NZMO34, also spotted a black 32 near baulkham hills tafe, a silver 32 turning off victoria ave, and a bayside blue 34 GTR JA-77-** in kellyville..think it was the top secret imports car
spotted at castle mall today, some lebbos parked next to you with red or green p's and were looking through your windows and i parked a few spots down and hung out for a minute untill they left.... i'm assuming this is r34liners car?????
oh oh that white R34 was the 1 i saw on pennat hills rd the other day :):P:D lol freaking hell ur cars look similar lol...
spotted yesty a black 34 with no wing, lowered, with noiiiice mags going down silverwater Rd at like 10:00, i was like 5 cars behind ya lol... and a white stagea going south along pennat hills rd at 2:00 saw ya 2 late 2 wave :banana: devo lol
oh oh that white R34 was the 1 i saw on pennat hills rd the other day :(:(:D lol freaking hell ur cars look similar lol...
spotted yesty a black 34 with no wing, lowered, with noiiiice mags going down silverwater Rd at like 10:00, i was like 5 cars behind ya lol... and a white stagea going south along pennat hills rd at 2:00 saw ya 2 late 2 wave :( devo lol
i know ay!! - i cant belive ther are 2 white r34 n/a green p platers in the same area!! thats just not fair lol - this is my area biatch :( - anyway next time you do see a white NA r34 with green p plates - make sure it has a - skylinesaustralia - sticker on the back windscreen and blue number plates with p plate zipped to the plate and NISMO sticker on the windsreen ;) i doubt ther is many skylines that look like that :(
Spotted Black R34 GTT on Winsor Road last night - wayy to dark to see any waveing tho
Spotted a M35 Stagea parked out the front of Repco in North Parramatta on Sunday. Looked very clean :(
Also spotted Abo Bob hanging around under my car :( Thanks again mate
spotted you in my driveway :(
Spotted about 1ish on Pennant Hills Rd, a silver R32 GTR and a black R33 a few cars behind it, waved at both but got nothing back :wub: I was in the blue R33.
Aww :( awkward movement hahaah!
Spotted "SLM.75J" today again on Sunnyholt rd
Spotted 2 black 33 GTST's parked a few spots apart in campbell st artarmon today. Plates BBU-*** and BDQ-***. Both had nismo stickers on the sides.
Also spotted a silver 33 GTR plates GTR-*** in lane cove industrial area. Gave a wave, then my tyre blew out seconds after lol.
lol wah????? so random, everything under controll i guess????
also spotted for a couple of days now a burnt orange r33 at macquarie (bank) i mean park, parked next to douglas hanly moir car park...
and shitty that mobil on corner carlingford road and beecroft road is out of 98 ron fuel again :D forced to fill up at penno BP that is way over priced
spotted you in my driveway :laugh:
:down:
Spotted a white R33 on pac highway in chatswood this morning with blue "HKS-33*" plates
Also saw that Duncan left his navigator on again ;) That can't be good for the batteries :P
Guest
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
