  • Replies 180
this ones for you bubba ;)
I've got the PSC with that on the front cover, insane piece of machinery.. TWO of the turbos that I've only got one of ;) oh and it's manual :(
But yes, that car is me to a T!
Edited by bubba
Not a Nissan. Alrighty
Mazda RX7 FC. Tuned to between 300-350rwkw. Stock exterior except for some gunmetal lightweight rims and ride height. Fresh coat of white paint with maybe a hint of pearl. Racing seats and Roll Cage.
Ok. the Following pics arnt exact to my mod selection. But gives the idea my thinking.
Hsv Coupe 4 (awd v8 coupe :P )
Although they rare and still expensive.
So I would opt for a monaro or regular hsv coupe (around the $20-$30k)
But thats because Ive stuffed around with turbo cars already and would want to try a v8 now. So if I never had the nissan, id prob look at a cheap xr6 turbo or a aw11 mr2 supercharged cause they look like a fun car to throw around haha
its this anime that makes AE86 sprinters soo farkin exxy for their age!
:):):) Initial D FC's!!!!
Edited by MeLSki
You know if i couldn't drive a Nissan then that pretty much rules out most of my favourite cars... And if im keeping it in the same price range, i hate to say it but i would probably buy a brand new Honda Civic Hybrid :)
Possibly one of the most gutless, understeering pigs on the road... But something about averaging 4.3L/100km is just appealing lol. And they aren't bad looking cars, at least it isn't a hatch back. And the engine turns itself completely off when you come to a stop, and on again when you take your foot off the brake, that is f**kin cool!
Thats probably what i would buy, considering the idea was we have to keep it in the same price range... Half the cars people mentioned here are 5 times as expensive as any Nissan!
*EDIT* Knowing how to beat the pig sensor FTW!!
Edited by Hanaldo
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
